Audi A4 Avant Allroad
- Tilmeldt: 30. sep 2008, 11:35
Hi
Er det nogle som ligger inde med info eller fotos af den nye Audi A4 Avant Allroad??
- Tilmeldt: 15. jun 2008, 18:50
- Geografisk region: Tyskland
- Geografisk sted: Tyskland
Re: Audi A4 Avant Allroad
Lidt info:
Like Volvo's XC line of cars, the Audi Allroad is a tall wagon with AWD and off-road capability. To date, however, the Allroad has only been available in a version based around the A6.
These latest spy photos show a new A4-based Allroad in testing, confirming our news last year that such a model was in the works.
Cues that tip this car as a definite Allroad vehicle include the wider fenders and taller ride height, plus the new bumpers with a more ruggedized look, new air intake housings, addition of foglights and other off-road specific design cues.
As yet it's not clear if the A4 Allroad will be available as both a sedan and a wagon, but reports suggest the car will be kept simple - meaning air suspension appears to be an unlikely option. Previous spy shots showed an Allroad sedan prototype, and if built the car could be considered a sort of up-scale alternative to the many rally-bred AWD sedans currently on offer, such as the Subaru WRX and Mitsubishi Evo X.
Other new features the A4 Allroad could adopt include a dual-clutch transmission and a new 2.0L turbodiesel engine. Power levels would range from 143hp (106kW) and 236lb-ft (320Nm) of torque to 170hp (126kW) and 258lb-ft (350Nm) of torque. A range topper could also be launched with 204hp (179kW) and 295lb-ft (400Nm) of torque available. The remainder of the engines would be the same as all A4 models, and all Allroads by nature feature quattro AWD.
Expect the car to make its world debut as a 2010 model at the Frankfurt Motor Show in September.
- Mortenr
forstår simpelthen ikke de modeller der... de er grimme fordi de er dækket til i uindfarvede plastic skærmforøgere og kofangere, og så er de højere end normalt, hvilket heller ikke ligefrem pynter. Hvis man vil ha en offroader/4wd så køber man da en rigtig...
MVH. Morten R
VW Golf 2 GTI 16V 1991
- Skyggen
- Tilmeldt: 11. jun 2008, 20:17
hold kæft den er grim.. Væk med det plastik på skærme, neee på mavsen og tadaaa!
/Skyggen
- marwie
- Tilmeldt: 14. jun 2008, 16:37
den er lige så grim som a6 eren der er ingen grund til at de laver de modeller, for der jo næsten ingen som køber dem
10 strøg på pølsen er bedere end 10 pølser på strøget.....
- barney
- Tilmeldt: 16. jun 2008, 21:25
- Geografisk sted: Copenhagen area, Karlslunde
Hvorfor er det lige det ser ud til den også kommer som en Limo Allroad...`?
- Det har jeg aldrig før set nogle sætte på gaden?
Tænker (Scout/Skoda - Allroad/Audi - Cross/VW - XC/Volvo osv.) er da alle i st.car / Avant modeller...
Ikke at det bliver kønnere af det...
Mvh Barney
+45 60 60 70 60
E-mail: dekongelige@gmail.com
Volkswagen Golf 1 Cabriolet + Audi S3 Sportback S-Tronic
+45 60 60 70 60
- Møbbe
- Tilmeldt: 14. jun 2008, 07:38
- Geografisk sted: Roskilde
- Has thanked: 11 times
- Been thanked: 128 times
But why??
Jeg forstår simpelthen ikke disse modeller - de ligner crap, og koster en arm
Mercedes EQC 400 4-matic
MiniCooper SE
MiniCooper SE
- Philip
- Geografisk sted: Arden
- Been thanked: 24 times
Aaaargh! Har du ikk glemt Polo Crossbarney skrev:Hvorfor er det lige det ser ud til den også kommer som en Limo Allroad...`?
- Sjeffe
- Tilmeldt: 14. jun 2008, 10:51
Der er en stolt tradition blandt VW og Audi for at smadre bilerne med lidt påklistret plastic:
Kønt er det ikke!
Men problemet med Allroaden er, at den blir for høj. Det klæder ikke en Audi!
Kønt er det ikke!
BMW 518 / BMW 520 / Golf VR6 / Golf V5 / Golf 4 GTI Turbo / Audi A4 Avant 1,8 Turbo SE 230 HK/ Golf 6 GTI /
- Philip
OT: så er det ikk kun Vag der sætter ulakeret lister og skærme mv. på deres offroad edition biler
- kimhemm
Der kørte nu mange af den gamle Allroad rundt i Norge og Sverige da jeg arbejdede derovre. Der gir den da lidt mening med sne om vinteren som en Avant, men forstår ikke helt konceptet med en Sedanmarwie skrev:den er lige så grim som a6 eren der er ingen grund til at de laver de modeller, for der jo næsten ingen som køber dem
Men indfarvet plastik og ned på maven ville ikke være helt dumt herhjemme
