Hej.
Motorvarningslampan tändes på min A6 2.0tdi 2012 idag, läste av felkoderna och fick ut detta.
Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2.0l TDI H24 9978
Revision: 45H24---
Coding: 12194012242401080000
Shop #: WSC 46661 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LA 003012
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: 74E25D50DF67BCE2DD-8020
1 Fault Found:
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 94506 km
Date: 2017.04.11
Time: 15:03:49
Engine speed: 1806.00 /min
Normed load value: 0.0 %
Vehicle speed: 97 km/h
Coolant temperature: 84 °C
Intake air temperature: 12 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.840 V
Unlearning counter according OBD: 40
Air mass: actual value (mg/stroke): 595.6 mg/stroke
Mean injection quantity: 0.00 mg/stroke
O2 sensor 1 bank 1: adjusted oxygen value: 0.00000
O2 sensor 1: bank 1: voltage raw value O2 signal: 831.4 mV
O2 sensor 1 bank 1: voltage reading Ri-signal: filtered.: 996.4 mV
O2 sensor 1 bank 1: duty cycle O2 heater: 46.84 %
Particle filter: difference pressure: 46 hPa
Någon som vet vad som kan vara fel, tacksam för hjälp.
//Magnus
Motorvarningslampan tändes, hjälp med felkod på A6 2.0Tdi
- Tilmeldt: 22. jan 2012, 17:14
- Kommerciel bruger: Pondusbiler
Re: Motorvarningslampan tändes, hjälp med felkod på A6 2.0Td
EOBD II Error Code: P2196
Fault Location:
Oxygen (Lambda) Sensor 1, Bank 1 - Signal Stuck Rich/Signal too High (Rich)
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) active.
Excessive Fuel Consumption.
Vacuum leaks.
Wiring/Connector(s).
Oxygen (Lambda) Sensor 1 (G39).
Fuel pressure.
Injectors.
Air intake restricted.
Possible Solutions:
Check/Replace all faulty Wiring/Connector(s).
Read Measuring Value Blocks (MVB).
Check/Replace Oxygen (Lambda) Sensor 1 (G39), Bank 1.
Description:
The front Oxygen (Lambda) Sensor 1 (G39) is placed into the exhaust manifold. It detects the amount of oxygen in the exhaust gas compared to the outside air. The Oxygen (Lambda) Sensor 1 (G39) has a closed-end tube made of ceramic zirconia. The zirconia generates voltage from approximately 1V in richer conditions to 0V in leaner conditions. The Oxygen (Lambda) Sensor 1 (G39) signal is sent to the Engine Control Module (ECM). The Engine Control Module (ECM) adjusts the injection pulse duration to achieve the ideal air-fuel ratio. The ideal air-fuel ratio occurs near the radical change from 1V to 0V.
As taken from my new EOBD II Fault Codes Software
Fault Location:
Possible Cause:
Vacuum leaks.
Fuel pressure.
Injectors.
Possible Solutions:
Description:
BIL:
Lupo3L 2001 i ekstra rød
Taget fra vw forums...
BIL:
