1.9tdi PD pluselig Egr / gløderørs fejl
- Tilmeldt: 20. nov 2009, 21:34
- Geografisk sted: 8600
Hejsa.
Motor lampe begyndte at lyse under en kørtur
fejl udlæst
fejl slettet og så kom de igen efter ca 100km
og de kommer på samme tid fejlen ?
nogle hint til evt rep ?
skull man prøve bell add i luftintag evt. " fik for 5-6000km siden"
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 016 CC HW: 028 101 183 2
Component and/or Version: R4 1,9L EDC 0000SG 6231
Software Coding: 0000071
Work Shop Code: WSC 06435 000 00000
VCID: 66C8336E280F
5 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1722 /min
Torque: 76.0 Nm
Speed: 44.0 km/h
Load: 25.1 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Mass Air / Rev.: 255.0 mg/str
Mass Air / Rev.: 620.0 mg/str
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame:
RPM: 1008 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 1008 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 1008 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame:
RPM: 966 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
vh
tommyt
fejl udlæst
VCID: 66C8336E280F
5 Faults Found:
P0401 - 000 - -
Freeze Frame:
RPM: 1722 /min
Torque: 76.0 Nm
Speed: 44.0 km/h
Load: 25.1 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
P0671 - 000 - -
Freeze Frame:
RPM: 1008 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
P0672 - 000 - -
Freeze Frame:
RPM: 1008 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
P0673 - 000 - -
Freeze Frame:
RPM: 1008 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
P0674 - 000 - -
Freeze Frame:
RPM: 966 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 11000100
Temperature: 8.1°C
Bin. Bits: 10110000
vh
tommyt
- kristian
- Geografisk sted: Aalborg
Evt 4 nye gløderør og et tjek om vakuum dåsen på Egr regulerer som den skal
Touareg 3,0TDI
Aalborg
Aalborg
- Jettadriver
- Been thanked: 19 times
Re: 1.9tdi PD pluselig Egr / gløderørs fejl
Gløderørs fejl får ikke lampen til at tænde - Det er EGR fejlen der gør det!
Bell-add er en mulighed og så skal den bare have på munden for fulde gardiner bagefter....
... others impressions!
Choose your own style!
syndes også det virker mærklig at 4 gløderør smutter på samme tid.
hvis jeg sletter fejl og så starter bil så kommer fejlen ikke igen.
men køre man så en tur så vupti gul motor fejl og logget de fejl som jeg har indsat.
har kikket slanger / stik og syndes ikke lige der er noget der mangler / afmonteret/faldet af
vh
tommy
ps:
bil: audi A3 med en 110 hk pd motor " hvis det hjælper"
vh
tommy
ps:
- Has thanked: 11 times
- Been thanked: 26 times
Du kan bare pille hætterne af gløderørene og tage en ledning op fra plus på batteri og prøve at sætte den på hvert gløderør og dem som ikke gnistrer er færdige, motorlampen tænder også for defekt gløderør
hvis 4 def gløderør ville den såjohannes skrev:Du kan bare pille hætterne af gløderørene og tage en ledning op fra plus på batteri og prøve at sætte den på hvert gløderør og dem som ikke gnistrer er færdige, motorlampen tænder også for defekt gløderør
1 være svær at starte ?
2 komme med det samme efter man starter bilen ?
det er som om fejlen på gløderør kommer sammen med ERG fejlen
vh
tommy
hejsa igen.
gløderør skiftet men stadig fejl
16785
http://wiki.ross-tech.com/wiki/index.ph ... 401/001025
kan man teste ERG ventil via VCDS
vh
tommy
16785
vh
tommy
- Uffe
- Geografisk sted: Bryrup
Prøv ny MAF sensor (lån en der virker hos en ven først).
Det er den der måler luftflow der kan sige lidt om EGR virker eller ej, så hvis du har fejl på den kan den sige EGR fejl.
Alt over 86hk er fråds.
Jeg er bare nærig.
Jeg er bare nærig.
- Mart0311
- Tilmeldt: 20. maj 2011, 13:58
- Geografisk sted: Espergærde
har du prøvet at lufte den godt igennem, ikke nødvendigvis hurtigt men i høje omdrejninger over et stykke tid, det har i hvert fald gjort tricket for mig, men jeg kører nok også for meget morfar til hverdag
/Martin
Fabia combi 1,9 TDI 2006
Nu uden EGR fejl i et år uden at gøre andet end Belladd og huske at sparke til den i ny og næ
/Martin
Venlig hilsen
Martin Sørensen
Skoda Fabia Combi 1,9TDI 2006 km 375.000
Martin Sørensen
hejsa.
Fik et skud BELLADD2d iaftes og en rask køretur
så vi ser lige de næste par dage om den kommer igen
vh
tommy
vh
tommy
hejsa igen desvære
gul lampe og
P0401 - 000 - -
Freeze Frame:
RPM: 1722 /min
Torque: 76.0 Nm
Speed: 44.0 km/h
Load: 25.1 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
vi har prøvet en anden Indsugningstryk-sensor " 038906051B"
men fejlen kom igen..
andre bud på fejlkomponent ?
vh
tommy
gul lampe og
P0401 - 000 - -
Freeze Frame:
RPM: 1722 /min
Torque: 76.0 Nm
Speed: 44.0 km/h
Load: 25.1 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
vh
tommy
- wahlstrom
- Has thanked: 24 times
Hvad med at få renset egr, med den nye belladd egr rens, og så få "lukket" for den bagefter???
Læser kun godt om at få lukket den... og hvis det ikk hjælper så er det jo gjort..
VW Golf GTE 2018
VW Up! 1.0 BMT 5d 2015
- Uffe
Fik du prøvet at skifte MAF sensor? Den du har skiftet er en tryksensor, den har ikke nogen relation til EGR problemet.
Jeg er bare nærig.
Jeg er bare nærig.
nope den er ikke prøvet i nu skal lige finde en lånerUffe skrev:Fik du prøvet at skifte MAF sensor? Den du har skiftet er en tryksensor, den har ikke nogen relation til EGR problemet.
vh
tommy
