http://wiki.ross-tech.com/wiki/index.php/P106B/004203
Tandhjulene i spjældet var kvadret - billigt plastiklort... Nyt spjæld er bestilt: http://www.vagcars.dk/phpbb/viewtopic.php?f=91&t=89672
Rosstech skriver følgende:
Men hvorfor bank 1 og 2? Så vidt jeg lige husker, så er der kun et af disse spjæld.Special Notes
When found on 3.0l CR-TDI (i.e. BKS/BUG) or 4.2l CR-TDI (BVN), the Learning Values have to be cleared after replacing the Throttle Body Control Module.
DO NOT CLEAR LEARNED VALUES IF YOU HAVE NOT REPLACED THE THROTTLE BODY CONTROL MODULE! Otherwise the proper values are being cleared and incorrect values are being learned.
[Select]
[01 - Engine] (for Bank 1/J388) or [11 - Engine 2] (for Bank 2/J544)
[Coding-II - 11]
Enable the Learning Procedure by Entering 10021.
[Do It!]
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch the Ignition OFF.
Switch the Ignition ON for 1 Second, then turn it OFF immediately.
Wait at least 30 Seconds, then switch the Ignition ON again.
Now Check if all remaining fault codes can be cleared.
