Hej venner, jeg vil lige høre om ikke disse fejl betyder 4 nye gløderør,eller om det er ledningsnettet, det er en Touran 1.9 årg 2008 med BLS motor
Saturday,10,May,2014,21:21:02:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVGZZZ1TZ8W098073 License Plate: FH90665
Mileage: 237970km-147867mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ8W098073 Mileage: 237970km/147867miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 RN HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1989
Revision: --H07--- Serial number: VWX7Z0GN3NF18T
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 7CFDECB03F15A6FEC8B-8029
3 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 27
Reset counter: 255
Mileage: 233719 km
Time Indication: 0
Date: 2000.00.00
Time: 20:10:09
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00101100
Temperature: 12.6°C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 233786 km
Time Indication: 0
Date: 2000.00.00
Time: 14:32:05
Freeze Frame:
RPM: 1764 /min
Speed: 64.0 km/h
Load: 38.0 %
Voltage: 14.52 V
Bin. Bits: 00101000
Temperature: 18.9°C
Bin. Bits: 10110000
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 255
Mileage: 235454 km
Time Indication: 0
Date: 2000.00.00
Time: 04:26:59
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00101100
Temperature: 9.0°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021190
VCID: 73EFC78C124BE986991-8026
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CG HW: 1K0 907 044 CG
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6ED9D6F87969C46E76F-803B
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007841028
Coding: 088B8F2100040F0047120C000000000000087B075C000100000000000000
VCID: 6FE7CBFC7E63CD667D9-803A
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 171107 021 0501
Coding: 00038805
Shop #: WSC 01324
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 HW: 1K0 919 475
Component: PARKHILFE 005 1104
Revision: 00005000 Serial number: 0 263 004 193
Coding: 000001
VCID: EFE74BFC3E634D66FD9-80BA
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D06YVR5
Coding: 0012340
VCID: 36693E9841B9BCAE7EF-8063
Subsystem 1 - Serial number: 6332QSME3A144437B
Subsystem 2 - Serial number: 6342QSME3A1C560FS
Subsystem 3 - Serial number: 6352QSME3B343A4FU
Subsystem 4 - Serial number: 6362QSME3B341571D
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 636 0070
Coding: 0002022
VCID: 75EBF9941C3FF7B6B75-8020
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 874 A HW: 1T0 920 874 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GN3NF18T
Coding: 0007101
Shop #: WSC 00038 204 00001
VCID: 346D049057C5AEBE40B-8061
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 071107F2001712
Coding: E9A01F06000A028002
VCID: 30650880A3DD929E243-8065
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1201
Coding: 0000053
VCID: 387530A04BAD4ADE6C3-806D
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CR HW: 1K0 959 433 CR
Component: KSG PQ35 G2 044 0203
Revision: 00044000 Serial number: 00000000000000
Coding: 8090020851030C7F2D06840560084B03E0BC00
VCID: 82011248DDF1500E027-80D7
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000052
VCID: 397335A470A753D693D-806C
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 037 0048
Revision: 00037000 Serial number: VWZ1Z2G6331511
Coding: 0020201
VCID: 68D5A0E05B8D1A5E3C3-803D
End ---------------------------------------------------------------------
Fejlkode på gløderør
Gå til
- VAG
- ↳ Teknik
- ↳ Dæk
- ↳ El
- ↳ Karosseri
- ↳ Klima/Aircon
- ↳ Motor
- ↳ Reservedele/Kataloger
- ↳ Transmission
- ↳ Undervogn
- ↳ Tuning
- ↳ Dieseltuning
- ↳ Benzintuning
- ↳ Udstødning
- ↳ Undervogn
- ↳ Styling
- ↳ Detailing
- ↳ Fælge
- ↳ Interiør
- ↳ Karosseri
- ↳ Lys/Lygter
- ↳ In Car Entertainment
- ↳ ICE - Generelt
- ↳ Multimedie/Navi
- ↳ Connected Services/Apps
- ↳ Diagnose/Kodning
- ↳ Diagnoseværktøjer
- ↳ Diagnose/Kodningshjælp søges
- ↳ Kodning af styreenheder/ekstraudstyr
- ↳ Brugen af VCDS/VAGCom
- ↳ Generel bilsnak om VAG
- ↳ Køb & Salg
- ↳ Køb - Købe guide - Alt vedr. køb
- ↳ Erfaringer med forhandlere
- ↳ Hvad er prisen?
- ↳ Hvor kan jeg købe?
- ↳ Købes
- ↳ Salg - Kommercielle brugere
- ↳ Salg - Rabataftaler
- ↳ Salg - Biler
- ↳ Audi Sælges
- ↳ Porsche Sælges
- ↳ Seat Sælges
- ↳ Skoda Sælges
- ↳ Volkswagen Sælges
- ↳ Salg - Reservedele
- ↳ Salg - Udstyr
- ↳ Salg - Tuning
- ↳ Salg - Dæk & Fælge
- ↳ 15" Sælges
- ↳ 16" Sælges
- ↳ 17" Sælges
- ↳ 18" Sælges
- ↳ 19" Sælges
- ↳ 20" Sælges
- ↳ 21" Sælges
- ↳ Salg - ICE
- ↳ Galleri/Show off
- ↳ Audi
- ↳ Porsche
- ↳ Seat
- ↳ Skoda
- ↳ Volkswagen
- ↳ Værkstedet
- ↳ Tech-Info - Guider
- ↳ Store projekter
- ↳ Hjælp til reparation & montering
- Efterlysning
- Lovgivning, regler, afgift og forsikring
- The Car Lounge
