ABS, ESP, Parkeringsbremsefejl
mouton
Tilmeldt: 14. jul 2013, 17:43
Indlæg af mouton » 10. dec 2016, 15:18
Hej.
Min Audi A4 2,0 TDI årg 2010 kom her forleden dag med advarsler for ABS, ESP, Parkeringsbremsefejl.
Har udlæst fejl, men er ikke helt sikker, men det tyder på ABS modulet. Eller kan det være noget andet.
Friday,09,December,2016,10:07:21:28171
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
http://www.Ross-Tech.com
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72 77
VIN: WAUZZZ8K0BN011431 Mileage: 169590km-105378miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 019 AT HW: 03L 906 019 AL
Component: R4 2,0L EDC H25 8434
Revision: 25H25---
Coding: 0A194012232403080000
Shop #: WSC 00014 204 81388
ASAM Dataset: EV_ECM20TDI03L906019AT A02006
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7DFB0DFFEC9F65AAD7-8028
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 169591 km
Date: 2016.12.09
Time: 10:04:05
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 43 °C
Intake air temperature: 17 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.080 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bit 0: 10000001
CCS status-Bit 0: 00101000
Cr Ctl st Sh Off Irv Lst-Bit 0: 11111111
Cr Ctl st Sh Off Rv Lst-Bit 0: 11111111
Cr Ctl v Des Dspl: 0.00 km/h
Sig Reset Env x Id-Bit 0: 00000000
Sig Reset Env x Id-Bit 8: 00000000
Cr Ctl st Shut Offirev-Bit 0: 00000000
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 169591 km
Date: 2016.12.09
Time: 10:04:05
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 02391 823 56573
VCID: 7EF90AF3E9997EB2CE-802A
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CC HW: 8K0 907 064 CC
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 032100
Shop #: WSC 02399 823 56573
VCID: 73EF2BC7D2DB23DAB1-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0071
Serial number: 0810000077838002
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000120496004
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
Component: KLIMA 1 ZONE H08 0180
Revision: A1000000 Serial number: 01280620101158
Coding: 34200000
VCID: 77F71FD7C6A34FFA8D-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 M HW: 8K0 907 063 M
Component: BCM1 1.0 H29 0392
Revision: 08029001 Serial number: 00000000579760
Coding: 6900C0B10034A7000001000300005F5F001C020806000101000000
VCID: 3973D9EFB037998ABB-806C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 230610 H06 0070
Serial number: SWF10060235060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10966079
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000107100687
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 169591 km
Time Indication: 0
Date: 2016.12.09
Time: 10:04:00
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0HNXXT
Coding: 30343435363030303030554A304C384B3053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 448DB81BCFF5D462D8-8010
Crash sensor for side airbag: driver side:
Serial number: 6334MSME5502304C4
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME550234766
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME39664500A
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME39662504D
Crash sensor for front airbag: driver side:
Serial number: 63732SME1E65021E%
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME2C622004S
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JG1000KX
Coding: 000016
Shop #: WSC 00014 204 62521
VCID: 3D7BCDFFA41FA5AA97-8068
Component: E221 - MFL H02 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 169591 km
Time Indication: 0
Date: 2016.12.09
Time: 10:04:05
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 P HW: 8K0 920 900 P
Component: KOMBIINSTR. H20 0258
Revision: 00100000 Serial number: EJ2108G6A
Coding: 0F3608000200000C010101
VCID: 3777DFD786238FFA4D-8062
2 Faults Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 108
Mileage: 169287 km
Time Indication: 0
Date: 2016.12.03
Time: 16:28:15
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 110
Mileage: 169328 km
Time Indication: 0
Date: 2016.12.04
Time: 12:52:06
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1061580AB
Coding: 00CF07
VCID: 0103710F9867014AB3-8054
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650279897
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H04 0003
Serial number: 10181001130011200410
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 N HW: 8T0 959 793 B
Component: TSG FA H07 1401
Coding: 011002204000410001
VCID: 54AD885B379544E248-8000
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0132338809
Coding: 0100062000B904408120013680000000
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 N HW: 8T0 959 792 B
Component: TSG BF H07 1401
VCID: 53AF8B47329B43DA51-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000685972
Shop #: WSC 00000 000 00000
VCID: 346DE8DB975564E268-8060
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 169591 km
Time Indication: 0
Date: 2016.12.09
Time: 10:04:04
Freeze Frame:
Voltage: 12.20 V
Count: 62
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H01 0300
Revision: 00000003 Serial number: AUZ5Z6I1168091
Coding: 05000482040185000159070000
Shop #: WSC 00014 204 184396
VCID: 448DB81BC7F5D462D8-8010
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010002204000210001
VCID: 56A97253216956F2B6-8002
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1401
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 E HW: 8T0 862 335 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005204436
Coding: 0010390
Shop #: WSC 02335 785 00200
VCID: 3C7DC0FB7F05ACA2A0-8068
End-------------------------(Elapsed Time: 02:35)--------------------------
Tilbage til "Undervogn"
