Ved forebredt alarm ... kan blink ved aktiv alarm, kun på blinklys.. ikke lyd
På nettet står der at B6 & B7 monteres på samme måde, på komfort styre boksen..
http://www.passat3c.info/cms_neu/index.php?page=158
Men jeg mener der sket ændringer fra årgang 2012...
Det ser ud til at:
Lydgiver monteres på BCM på klemme 52-pin
på connector -T52 C- brown-C-
klemme 2 - Alarm system horn -H18-
og kabine sensor på
52-pin connector -T52 B- white-B-
Klemme 36 - Alarm horn -H12-Interior monitoring sensor -G273-
er det korrekt forstået ??
________________________________
Onboard supply control unit -J519-
Only models with Pr. number AW1
Fitting location:
under dash panel on driver side, under relay carrier
Connector assignment:
52-pin connector -T52 A- black -A-
1 - Fuse 26 on fuse holder B -SB26-
2 - Not assigned
3 - Not assigned
4 - Right washer jet heater element -Z21-
5 - Left headlight main beam bulb -M30-
6 - Not assigned
7 - Left daytime running light bulb -L174-
8 - Right daytime running light bulb -L175-
9 - Rear right turn signal bulb -M8-
10 - Front left turn signal bulb -M5-
11 - Left headlight dipped beam bulb -M29-
12 - Not assigned
13 - Rear lid handle release button -E234- , soft touch
14 - Bonnet contact switch -F266-
15 - Not assigned
16 - Reversing light switch -F4-
17 - Rear fog light switch -E18-
18 - Light switch -E1- , zero position
19 - Light switch -E1- , side lights
20 - Light switch -E1- , driving light assist
21 - Fog light switch -E7-
22 - Light switch -E1- , dip beam
23 - Earth connection 2, in main wiring harness-367-
24 - Positive connection 24 (30a), in main wiring harness -B684- terminal 30ref
25 - Left fog light bulb -L22-
26 - Right brake and tail light bulb -M22-
27 - Left tail light bulb -M4- , rear left tail light
28 - Left reversing light bulb -M16-
29 - Rear lid lock unit -F256-
30 - Rear right door contact switch -F11-
31 - Not assigned
32 - Not assigned
33 - Not assigned
34 - Not assigned
35 - Heater/heat output switch -E16-
36 - Interior monitoring deactivation switch -E267-
37 - Rear left door central locking motor, lock -V214-
38 - Rear left door control unit -J388-
39 - Rear right door control unit -J389-
40 - Rear left door control unit -J388-
41 - Rear left door contact switch -F10-
42 - Earth connection 2, in main wiring harness -367-
43 - Washer pump -V5-
44 - Right side light bulb -M3-
45 - Additional brake light bulb -M25-
46 - Tank filler flap locking motor -V155-
47 - Not assigned
48 - Rear left central locking lock unit -F222-
49 - Rear right door central locking motor, lock -V215-
50 - Not assigned
51 - Button illumination bulb -L76-Connection 1 (58d), in main wiring harness -B340-
52 - Not assigned
1 - Fuse 36 on fuse holder C -SC36- , central locking
2 - Washer pump -V5-
3 - Not assigned
4 - Not assigned
5 - Tank filler flap locking motor -V155-
6 - Not assigned
8 - Rear right central locking lock unit -F223-
9 - Not assigned
10 - Not assigned
11 - Rear lid release motor -V139-
12 - Terminal 15 voltage supply relay 2 -J681-
13 - Not assigned
14 - Heater/heat output switch -E16-Heated rear window warning lamp -K10-
15 - Switch and instrument illumination regulator -E20-
16 - Sliding sunroof control unit -J245-
17 - Sliding sunroof adjustment control unit -J245- , convenience closing
18 - Wiper motor switch-over relay 1 -J368-
19 - Not assigned
20 - Wiper motor -V-
21 - Heated front seats control unit -J774-
22 - Heated rear window relay -J9-
23 - Wiper motor switch-over relay 2 -J369-
24 - Hazard warning lights button -E229-
25 - Not assigned
26 - Rear left door central locking SAFE function motor -V163-
27 - Rear right door central locking SAFE function motor -V164-
28 - X-contact relief relay -J59-
29 - Terminal 50 voltage supply relay -J682-
30 - Switch and instrument illumination regulator -E20-
31 - Not assigned
32 - Not assigned
33 - Rain and light detector sensor -G397- , LIN bus
34 - Not assigned
35 - Not assigned
37 - Interior monitoring deactivation switch -E267-
38 - Fuel supply relay -J643-
39 - Not assigned
40 - Headlight washer system relay -J39-
41 - Dual tone horn relay -J4-
42 - Fuse 48 on fuse holder C -SC48-
43 - Positive connection, in roof wiring harness -B250-
44 - Not assigned
45 - Not assigned
46 - Not assigned
47 - Not assigned
48 - Not assigned
49 - Not assigned
50 - Not assigned
51 - Connection 1 (58d), in main wiring harness -B340-
52 - Earth connection 2, in main wiring harness -367-
52-pin connector -T52 C- brown-C-
1 - Positive connection (30), in dash panel wiring harness -A32-
3 - Connection (58R), in dash panel wiring harness -A85-
4 - Left brake lamp bulb -M9- , left tail lamp -MX3-
5 - Earth connection 2, in main wiring harness -367-
6 - Not assigned
7 - Hazard warning lights button -E229-
8 - Not assignedø"
9 - Not assigned
10 - Connection 1 (TK), in interior wiring harness -B154- , front interior light -W1-
11 - Not assigned
12 - Not assigned
13 - Steering column electronics control unit -J527-Ignition/starter switch -D- Terminal S, Electronic steering column lock control unit -J764-
14 - Positive connection (50), in main wiring harness -B276-Steering column electronics control unit -J527-
15 - Data bus diagnostic interface -J533-Connection 2 (convenience CAN bus, high), in main wiring harness -B407-
16 - Data bus diagnostic interface -J533-Connection 2 (convenience CAN bus, low), in main wiring harness -B407-
17 - Brake light switch -F-
18 - Not assigned
19 - Not assigned
20 - Not assigned
21 - Not assigned
22 - Not assigned
23 - Not assigned
24 - Entry and start authorisation control unit -J518-
25 - Connection (fog light), in main wiring harness -B554-
26 - Left side light bulb -M1-
27 - Positive connection (58), in number plate lights wiring harness -W41-
28 - Connection (RL), in dash panel wiring harness -A87-
29 - Not assigned
30 - Mechatronic unit for dual clutch gearbox -J743- P-N / Earth connection 3, in main wiring harness -368- , start/stop
31 - Steering column electronics control unit -J527-
32 - Connection (61), in interior wiring harness -B177- / heater control unit -J162-
33 - Not assigned
34 - Not assigned
35 - Switch and instrument illumination regulator -E20-
36 - Not assigned
37 - Not assigned
38 - Not assigned
39 - Not assigned
40 - Central locking and anti-theft alarm system aerial -R47- , aerial screening
41 - Central locking and anti-theft alarm system aerial -R47-
42 - Fuse 29 on fuse holder B -SB29-
43 - Not assigned
44 - Not assigned
45 - Not assigned
46 - Right headlight main beam bulb -M32-
47 - Rear left fog light bulb -L46-
48 - Not assigned
49 - Not assigned
50 - Front right turn signal bulb -M7-
51 - Rear left turn signal bulb -M6-
52 - Right headlight dipped beam bulb -M31-
DWA+ Tyveri alarm
- stroma
- Tilmeldt: 5. apr 2012, 18:32
- Has thanked: 11 times
Re: DWA+ Tyveri alarm
er der nogle der ved om det er muligt at monteret til BCM istedet for komfort styre enheden (tror det er det den hedder)
Bare så jeg tilslutter alarm hornet det rigtig sted
Hilsen
Ryan
Ryan
