Hey
Har lige fået min VCDS stick. Har rodet lidt med at få slået can-bus fra på baglyset, da jeg har fået sat LED i og er lidt træt af fejlkoden.
Nogle der kan hjælpe med hvor jeg finder det?
Auto scan:
Monday,23,July,2018,08:32:42:29174
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: VSSZZZ5FZGR018123 License Plate:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: VSSZZZ5FZGR018123 Mileage: 77651km-48250miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-DBKA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 CA HW: 04L 907 309 R
Component: R4 1,6L EDC H21 1662
Revision: B5H21---
Coding: 01190012032401090000
Shop #: WSC 00049 770 00125
ASAM Dataset: EV_ECM16TDI01104L906026CA 002004
ROD: EV_ECM16TDI01104L906026CA_002.rod
VCID: 6B833BDAE302EF3FB46-803E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 61555000001159
Coding: 20EE6292142109740078060241C6240446289000608224F200410070C002
Shop #: WSC 00049 770 00197
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_SE37.rod
VCID: 4BC39B5A83420F3FD46-801E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 68
Mileage: 4085 km
Date: 2015.11.07
Time: 11:00:08
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5F0 907 044 J HW: 5F0 907 044 J
Component: Climatronic H04 0911
Revision: 00001K09
Coding: 00000104202100011005000000101000
Shop #: WSC 00049 770 00103
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_003_SK37.rod
VCID: 2D07F5C21D96210FEA2-8078
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
1 Fault Found:
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
[PTC-Reduzierung durch MSG]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 76997 km
Date: 2018.07.14
Time: 12:38:10
Voltage terminal 30: 13.9 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Specified value: 1
Auxiliary heater: in stages-Specified value for control: 1
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061515901497
Coding: 08000846424102FB4BE44000401C07081000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 094F6152C9BE5D2F26A-805C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150505 041 0574
Serial number: 150520121218
Coding: 0BC5FD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y15M06D16H01M01S04
Coding: 00095D
4 Faults Found:
5130 - Bulb for Front Left Turn Signal
B11E8 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 189
Mileage: 76963 km
Date: 2018.07.13
Time: 17:41:10
5642 - Bulb for Rear Left Turn Signal
B11E9 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 180
Mileage: 76331 km
Date: 2018.06.29
Time: 16:28:04
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 76376 km
Date: 2018.07.01
Time: 19:09:55
14602 - Bulb for Left Brake Lamp / Tail Lamp
B133A 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 38
Reset counter: 195
Mileage: 76337 km
Date: 2018.06.30
Time: 15:39:02
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPBK4HEJ
Coding: 98CCC000000000005C0000CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7B4F4AB7DA731FF8E-805A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 000 406 15
Component: SideSensor_Df 008 0887
Serial number: 3576U0000006956CA41I
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 000 406 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000931A0E418
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 800 306 15
Component: SideSensor_Dr 301 0148
Serial number: 3516R43813107000000Q
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 801 006 15
Component: SideSensor_Pr 301 0148
Serial number: 3526R81A22F070000002
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 802 605 15
Component: FrontSensor_D 304 0149
Serial number: 3556V4E631B07000000A
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 08061504401292
Coding: 1400
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 7EA5028E80706A97038-802A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5F0 920 863 A HW: 5F0 920 863 A
Component: KOMBI 203 6420
Coding: 07A402002180000800082A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 280904D632740427194-807C
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2223
Revision: -------- Serial number: 31051510802450
Coding: 030100F40F087300EA000240000F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_SE37.rod
VCID: 74B120A6BE3C30C765C-8020
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0147180515
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001505233262
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000153766333
Coding: 00100320C000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 47CBA76A9F2AEB5FF0E-8012
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000006313329
Coding: 310000
2 Faults Found:
589827 - Window Regulator; Rear Driver Side
B131F 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 160
Mileage: 75779 km
Date: 2018.06.13
Time: 19:06:47
589837 - Window Regulator Motor; Front Driver Side
B1321 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 182
Mileage: 75704 km
Date: 2018.06.12
Time: 16:06:29
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 43D3B37AAB12C77F2C6-8016
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000153526568
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 46D5AA6E9820F2570B8-8012
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000006343779
Coding: 290000
1 Fault Found:
65639 - Motor for Window Regulator
B1487 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 182
Mileage: 75437 km
Date: 2018.06.05
Time: 09:25:33
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 871 HW: 5F0 035 871
Component: MU-E--ER 851 6481
Serial number: 29051500011120
Coding: 04730000BE00000011110001000008002F0003840000010000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 639353FA0BD2A77F0C6-8036
1 Fault Found:
7203 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Efficiency program (0x23) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Reset counter: 195
Mileage: 16 km
Date: 2015.08.19
Time: 08:59:05
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 00
End----------(Elapsed Time: 01:22, VBatt start/end: 14.6V/14.7V)-----------
Slå cold dianostic fra på pærer
- Tilmeldt: 24. maj 2018, 19:19
- Been thanked: 10 times
Har VCP, VCDS, ODIS-E, ODIS-S. Etka og Elsawin.
Nuværende bil:
Golf 7.5 1.5 TSI 130HK
Nuværende bil:
- Geografisk sted: Kalundborg
- Been thanked: 20 times
Re: Slå cold dianostic fra på pærer
Kan ikke finde den enhed de ændrer det på i linket
Nuværende bil:
Nuværende bil:
- Has thanked: 3234 times
- Been thanked: 4578 times
seatleon111 - er din bil ikke en 2016 Seat Leon 5F ?
I så fald kan opskriften til en 2010 Audi A4 (som er den Joker22 linker til) i hvert fald ikke bruges til noget.
Din bil er en MQB bil og derfor styres lysopsætning på en helt anden måde.
Det er noget med ½ mio tilpasningskanaler hvor kunsten er at finde den rigtige. Der findes folk herinde der har mere styr på de sager.
Du kender ikke nogle herinde der har styr på den slags?
Kan godt se der er mange muligheder, når jeg går derind og kigger
Tak
Tak
Nuværende bil:
Nuværende bil:
Kan se at du er fra Nordjylland.seatleon111 skrev: ↑23. jul 2018, 11:03Hej
Tak
Jeg vil foreslå at du tager fat i firmaet Cartrends, som oppe ved dig er repræsenteret ved Tim. De har lokaler i Hjallerup og er dygtige.
Du kan f.eks. kontakte ham herinde som bruger DJ_Gran.
Det vil jeg prøve
Tak for hjælpen
Tak for hjælpen
Nuværende bil:
Nuværende bil:
