Gearskifte I Instrumentpanel Blinker
- Tilmeldt: 29. jan 2017, 19:28
- Geografisk sted: ALS
i mit instrumentpanel er gearskiftet begyndt af blinke, hvad kan det betyde ?
Det er en golf plus 1,4 tsi fra 2009 automatgear
hilsen
thrill
hilsen
thrill
\Thrill
Golf Plus 2009 1.4 TSI, DSG
- majbom
- Geografisk sted: Midtfyn
- Has thanked: 108 times
- Been thanked: 176 times
Re: Gearskifte I Instrumentpanel Blinker
det her viser det, men jeg bliver ikke meget klogere af det, måske du kan fortælle mig hvad det betyder.
Skal der en ny hydraulik pumpe på eller ?
Address 02: auto trans labels: 0am-927-769.lbl
part no sw: 0am 300 048 l hw: 0am 927 769 d
component: gsg dsg ag7 402 9032
revision: 00040024 serial number: tfk00904280146
coding: 0000020
shop #: wsc 46207 001 1048576
vcid: 397eb5cb704a35e9691-806c
3 faults found:
006079 - hydraulic pump
p17bf - 000 - play protection - intermittent
freeze frame:
fault status: 00100000
fault priority: 0
fault frequency: 5
reset counter: 10
mileage: 199818 km
time indication: 0
date: 2011.09.21
time: 12:19:34
p17bf - 001 - play protection - intermittent
freeze frame:
fault priority: 0
fault frequency: 5
reset counter: 10
mileage: 199818 km
time indication: 0
date: 2011.09.21
time: 12:19:34
p17bf - 002 - play protection - intermittent
freeze frame:
fault priority: 0
fault frequency: 5
reset counter: 10
mileage: 199818 km
time indication: 0
date: 2011.09.21
time: 12:19:34
coding: 0000020
3 faults found:
freeze frame:
fault priority: 0
fault frequency: 5
reset counter: 10
mileage: 199818 km
time indication: 0
date: 2011.09.21
time: 12:19:34
freeze frame:
fault priority: 0
fault frequency: 5
reset counter: 10
mileage: 199818 km
time indication: 0
date: 2011.09.21
time: 12:19:34
freeze frame:
fault priority: 0
fault frequency: 5
reset counter: 10
mileage: 199818 km
time indication: 0
date: 2011.09.21
time: 12:19:34
\Thrill
- Tilmeldt: 13. jun 2008, 18:09
Prøv og kig ned på din bundplade. Den er garanteret våd af hydraulikolie fra mechatronikenheden til din gearkasse.
Hej michael
ja, du har ret, der er en del olie på bundpladen.
Jeg har desværre ingen anelse om hvad en mechatronikenheden er, kan du forklare mig hvad jeg skal gøre for at få skaden udbedret ?
Skal den skiftes ?
Pris ca. ?
Hilsen
thrill
Skal den skiftes ?
Pris ca. ?
Hilsen
thrill
\Thrill
Mechatronikenheden er den enhed der sidder påskruet din gearkasse og styrer gearskifte samt koblinger. Den skal desværre skiftes, da det er en lukket enhed uden mulighed for og købe løse dele til. Hvis du har passet service ved VW kan du være heldig de vil deltage økonomisk i reparationen. Der er en aktion (opdatering) på nogle af disse 7 trins dsg kasser, da oliepumpen i mechatronikenheden kan lave for højt tryk og beskadige mechatronikenheden(bliver utæt)
Hej Michael
Du fik ret.
Det var megatroniken der skulle skiftes
Mange tak for hjælpen
\Thrill
Du fik ret.
\Thrill
\Thrill
- Geografisk sted: Slagelse
Fik du en ny eller brugt på?? hvad har du givet??
Har bestilt en ny 7 trins med montering ved VW, pris 19,375
\Thrill
Sørg også for og få den nye enhed opdateret. Den bliver utæt pga. oliepumpen laver for højt tryk. Håber VW kunne tilbyde noget kulance
- Has thanked: 3496 times
- Been thanked: 4882 times
Øv! Har lige fået samme fejl, og nogle dråber klar olie under bilen.
Der er vist ikke så meget at være i tvivl om...
- majbom
Træls!HansH skrev:Øv! Har lige fået samme fejl, og nogle dråber klar olie under bilen.
Krydser sgu fingre for at det kan fixes for mindre end 20k
- Has thanked: 59 times
- Been thanked: 222 times
Forhåbentlig nu kan man få diverse rep kit til mechatronic enhederne.
Det mest normale er vist nok det her plastikhus der revner.
https://www.ebay.com/i/174033672413?mke ... kQQAvD_BwE
Jeg håber på at fortiden kommer mig til hjælp, så at sige...
I starten af december sidste år fik jeg renoveret min MT enhed.
3 af de 8 ventiler der sidder i den var defekte, og de blev skiftet. Da jeg undrende spurgte firmaet hvorfor hulen de ikke skiftede de resterende 5 når de nu var i gang (de koster ikke mange basseører), lød svaret -
"Vi skifter kun de defekte stumper, men for dig er det en renoveret enhed med 2 års garanti. Hvis der bliver noget som helst med den MT de næste 2 år, så er det vores problem. Det er altså vores gambling at vi kun skifter det vi synes, fremfor at skifte det hele"'
Såå... det skulle jo helst vise sig nu, at der er substans bag den salgstale
Det er lige præcis den trykbeholder der er problemet.styker skrev: ↑8. maj 2021, 22:21Forhåbentlig nu kan man få diverse rep kit til mechatronic enhederne.
Imidlertid - som jeg har forstået det - er det faktisk selve ventilhuset (også kaldet "ormegården") som trykbeholderen er skruet ned i, som flækker.
Men du har helt ret i, at der fås disse repair kits som gør at problemet kan fikses langt nemmere og ikke mindst billigere, end i gamle dage hvor det hed udskiftning af hele MT'en.
Update på dette:
Bilen har i denne uge været ved Autogearnord hvor jeg har 1½ år tilbage af garanti på renoveret MT.
Der var ingen problemer - de skiftede til helt nyrenoveret ventilhus med alle ventiler, oliepumpe og trykbeholder.
Problemet var helt som forventet - ventilhuset var revnet ved bunden af trykbeholderen.
Så nu kører mukkebikken fint igen.
Siden fejlen opstod har bilen kørt fint nok. Blot har gearindikatoren blinket mellem gear og "skruenøgle" efter ca 10 min kørsel.
Men derudover spildte den jo også olie fra MT'en.
Det stod derfor klart, at på et tidspunkt har den smidt så meget olie at den ikke længere kan lave tryk til at lukke koblingerne og skifte gear .... og så kan bilen ikke køre!
Man kan heller ikke bare lige åbne et sted og så toppe den olie op .. ligesom man kan med motorolie.
Så derfor lod vi den stå den sidste uge op til aftalen hos Autogearnord, da jeg ikke turde gamble med det. Det koster alligevel lidt mønt at skulle have vejhjælp til at fragte den fra Taulov til Brønderslev... så det ville jeg jo helst undgå.
Den klarede heldigvis turen derop fint, og da jeg afhentede den hos Autogearnord spurgte jeg til det.
"Hmm.. det var tæt på. Der var godt nok ikke meget olie tilbage i den MT. Der var så lidt, at den var begyndt at piske det til skum .... ligesom hvis du tænder for boblebadet med for lidt vand i.."
Såå... pyha! Godt vi valgte at lade den stå, og at den lige kunne klare turen derop.
En fortælling fra bogen "Livet med en gammel DQ200"
- Tilmeldt: 18. nov 2022, 16:41
MIn er lige begyndt på det samme skidt.HansH skrev: ↑8. maj 2021, 22:41Det er lige præcis den trykbeholder der er problemet.styker skrev: ↑8. maj 2021, 22:21Forhåbentlig nu kan man få diverse rep kit til mechatronic enhederne.
Leder med lys og lygte efter det rep kit i omtaler , har i nogen idé om hvor det kan anskaffes ?
Prøv at kontakte den bruger der hedder Gigel herinde (han hedder George i civil) -- memberlist.php?mode=viewprofile&u=1200
Du kan ikke skrive PB til ham før du har 3 indlæg.
Men du kan bruge email funktionen.
Gigel har rodet rigtig meget med DSG gearkasser. Du kan også finde ham på youtube hvor han har en channel der hedder Gigibelea aka JAX - https://www.youtube.com/@GigiBeleaDK
Jeg mener han har lavet en video på et tidspunkt, hvor han viser montering af det kit.
Måske han kan / ved hvor man kan skaffe det....
- Has thanked: 523 times
- Been thanked: 246 times
Uha, det er virkelig informativ at se video. Men tror altså ikke jeg lige går igang selv, men forklaring er rigtig god..
Holder mig til at få HansH til at nulstille dsg og mærke efter glidende kobling
Tidligere : Citroen c4 2007
Denne video på YT viser hvordan kit'et installeres.
Måske firmaet bag kan kontaktes .. det lyder som om de sælger det ?
