hejsa min fars gammel audi a8 4.2L 299hk fra 1995 vil ikke rigtig gå i baggear før den går i nødprogram og kan ikke rigtig finde fejlen. og vil ikke tage det sidste gear med når den køre frem af. han er ved at give op. men det er hans lille baby
og udskrev fra vcds ser sådan ud.
håber nogen kan hjælpe.
Chassis Type: 4D - Audi A8 D2 (1994 > 2003)
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
Mileage: 497870km-309362miles
Address 25: Immobilizer Labels: 4A0-953-234.lbl
Part No: 4A0 953 234
Component: IMMO AUZ9Z0R8075961 D72
Coding: 00000
Shop #: WSC 00735
VCID: 5F38794B585F1D3A3D-5178
No fault code found.
Address 01: Engine Labels: Redir Fail!
Part No: 4D0 907 557 E
Component: 4,2L V8/4V MOTR AT D01
Coding: 04263
Shop #: WSC 00000
VCID: 2E0BDFDE9420F763A5-4B4A
2 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
00545 - Engine-Transmission Electrical Connection
03-10 - No Signal - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 J
Component: ABS/EDS BOSCH 5 7365
Shop #: BB 37365
VCID: 3512ADC9B00D19106D-515A
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4D0 820 043
Component: D2-KLIMAVOLLAUTOMAT_D02
Coding: 00080
Shop #: WSC 23146
VCID: 593E755D4079F10C4D-2578
1 Fault Found:
01270 - A/C Magnetic Clutch (N25)
36-10 - Open Circuit - Intermittent
Address 15: Airbags Labels: None
Part No: 4D0 959 655
Component: AIRBAG III AUDI D00
Coding: 00127
Shop #: WSC 02314
VCID: 6F48599B98EF7DAABD-4B18
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01025 - Trigger for On Board Diagnostic Lamp; Malfunction
31-00 - Open or Short to Ground
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No: 4D0 919 033 F
Component: D2-KOMBIINSTRUMENT__D13
Coding: 00183
Shop #: WSC 00186
VCID: 2700C9E37847CDB2FD-513C
Address 02: Auto Trans Labels: None
Part No: 4D0 927 156 E
Component: AG4 GETRIEBE 018 D24
Coding: 00000
Shop #: WSC 00000
VCID: 2B0CD1D78853E54EDD-508E
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End-------------------------(Elapsed Time: 06:41)--------------------------
Audi a8 4.2L vil ikke går i gear (automat gear)
- Tilmeldt: 27. maj 2017, 14:13
Re: Audi a8 4.2L vil ikke går i gear (automat gear)
Hvornår er der sidst skiftet olie på gearkassen?
Hvor gammel er batteriet / er der målt ud mht effekt?
- Tilmeldt: 2. aug 2013, 10:09
onslow skrev:Hvornår er der sidst skiftet olie på gearkassen?
Hvornår er der sidst skiftet olie på gearkassen kan jeg ikke svare på. min far køre 3-5000km om år og har ikke fået det gjort de 4år han har haft den.
batteriet er et af de store Varta og er monteret for ca 1år siden og er blevet testet og skulle være iorden
Jeg tænker :
http://wiki.ross-tech.com/wiki/index.php/00545
Check ledningsnet.
Herudover;
http://wiki.ross-tech.com/wiki/index.ph ... 602/005634
Hvis dette ikke giver noget så skift olien på gearkassen. Husk bilen skal være vandret og olien mellem 35-45 grader når den løber over i fyldhullet. Temp kan aflæses i VCDS eller brug et lasertermometer.
Google evt for mere præcis vejledning. Mener det er ZF gearkasse der sidder på den. ZF har online vejledninger til det tror endda det er på youtube
Check ledningsnet.
Herudover;
