Kabinelyset virker ikke i min passat. Når jeg åbner dørene tændes lyset ved sidespejlene, men kabinelyset tændes ikke. Det kan heller ikke tændes på knappen i loftet.
Jeg har udlæst følgende fejl:
5 Faults Found:
00059 - Terminal 30 for Interior Lighting
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 1
Fault Frequency: 5
Reset counter: 106
Mileage: 129734 km
Time Indication: 0
Date: 2017.04.12
Time: 08:18:17
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 106
Mileage: 129734 km
Time Indication: 0
Date: 2017.04.12
Time: 08:18:17
00833 - Signal for Activation of Heated Windshield
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 2
Reset counter: 140
Mileage: 130164 km
Time Indication: 0
Date: 2017.04.15
Time: 22:55:49
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 140
Mileage: 130164 km
Time Indication: 0
Date: 2017.04.15
Time: 22:55:49
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 140
Mileage: 130164 km
Time Indication: 0
Date: 2017.04.15
Time: 22:55:49
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
Kabinelys - Passat 2012
- Tilmeldt: 10. jun 2009, 22:48
Audi A3 8p 1,8 TFSi [solgt]
VW UP! 1.0 Life 2014
VW Passat 2.0 TDI Comfortline 2012
