Min fætters 3c skaber sig indimellem, han siger at når han putter nøglen i går der nogle sekunder inden der kommer liv i speedometeret, altså lamper osv. lyser op.
Han synes også have oplevet servoen er væk kort.
Jeg tænker rat elektronik eller måske bundstykke baseret på startspærre fejlkoder. Nogle med andre ideer ?
PFT !
Saturday,20,May,2017,17:25:30:30234
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ3CZ6E073764 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
VIN: WVWZZZ3CZ6E073764 Mileage: 122180km-75919miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-906-056-BLR.lbl
Part No SW: 06F 906 056 AM HW: Hardware No
Component: MED9.5.10 G00 7553
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 05311 000 08193
VCID: 74C885F917CD35E1F7-8020
1 Fault Found:
005488 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 121381 km
Time Indication: 0
Date: 2000.00.00
Time: 08:40:20
Freeze Frame:
RPM: 1200 /min
Load: 41.9 %
Speed: 0.0 km/h
Temperature: 5.0°C
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658057527
Coding: 0013710
Shop #: WSC 00039 204 84326
VCID: 2F424A95BE6B56394A-807A
1 Fault Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 122121 km
Time Indication: 0
Date: 2000.00.00
Time: 09:04:38
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 Q HW: 3C0 907 044 Q
Component: ClimatronicPQ46 042 0202
Revision: 00042004 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002064931
Coding: 088C8F0700041A00000A00000F000000000959435C0000
Shop #: WSC 05311 000 00000
VCID: 2E7C5791B9615F3141-807A
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 05311
2 Faults Found:
00093 - Terminal 15 for Starting Relevant Consumers
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 122121 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
02403 - Terminal 15 for Interior
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 122121 km
Time Indication: 0
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 F HW: 3C0 909 605 F
Component: 01 AIRBAG VW8 029 2421
Revision: 08029000 Serial number: 0039USG9D0P4
Coding: 0012337
VCID: 2976A48D808F380994-807C
Subsystem 1 - Serial number: 6332MSME0B13330F
Subsystem 2 - Serial number: 6342MSME0B034D0C
Subsystem 3 - Serial number: 6351HTS65CHEL4V2
Subsystem 4 - Serial number: 6361HTS68SD6A6C2
Subsystem 5 - Serial number: 6371VTS68SDQQ5I2
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507C
Coding: 0000014
VCID: 2A745B81858933119D-807E
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 860 HW: 3C0 920 860
Component: KOMBIINSTRUMENT VD1 4030
Revision: V0013000 Serial number: 00000000000000
Coding: 0005105
Shop #: WSC 11111 111 11111
VCID: 5FE2FA558E4B86B9BA-800A
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0580905C7
Coding: 3DFD8C04C22002
Shop #: WSC 05311 123 12345
VCID: 2166BCADF8BFF049CC-8074
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 6AF49B814509F3115D-803E
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
3 Faults Found:
02861 - Electronic Steering Column Lock Check Sum Error
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 100
Mileage: 122121 km
Time Indication: 0
Date: 2000.00.00
Time: 09:03:49
02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 121761 km
Time Indication: 0
Date: 2000.00.00
Time: 07:15:28
02811 - Control Module for Electronic Steering Column Lock (J764)
014 - Defective - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 121761 km
Time Indication: 0
Date: 2000.00.00
Time: 07:15:28
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0000181
VCID: 364C7FF1413167F109-8062
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 324443E1AD597BD125-8066
1 Fault Found:
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0472
Coding: 0091020851030E763004941570084F0B603CA0
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 375272F5463B9EF912-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
1 Fault Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 100
Mileage: 122120 km
Time Indication: 0
Date: 2000.00.00
Time: 09:04:22
Freeze Frame:
Voltage: 11.90 V
Count: 41
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E1880717
Coding: 0040400
VCID: 334A46E5524372D92E-8066
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2505
Coding: 0000144
VCID: 70C089E963D509C113-8024
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008200799458
Coding: 0100000100000000
VCID: 304049E9635549C153-8064
4 Faults Found:
02562 - Trailer; Brake Lamps
010 - Open or Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 93
Mileage: 121956 km
Time Indication: 0
Date: 2000.00.00
Time: 08:14:48
02565 - Trailer; Right Turn Signals (M63)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 93
Mileage: 121956 km
Time Indication: 0
Date: 2000.00.00
Time: 08:14:48
02566 - Trailer; Left Turn Signals (M62)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 93
Mileage: 121956 km
Time Indication: 0
Date: 2000.00.00
Time: 08:14:49
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 93
Mileage: 121956 km
Time Indication: 0
Date: 2000.00.00
Time: 08:14:49
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
VCID: 71C68CED68DF00C91C-8024
End-------------------------(Elapsed Time: 01:13)--------------------------
Passat 3c - Rat elektronik eller bundstykke ?
- Has thanked: 3208 times
- Been thanked: 4541 times
Re: Passat 3c - Rat elektronik eller bundstykke ?
Mit umiddelbare gæt er ratstammelås. En kendt svaghed på B6.. måtte skifte den på min.
http://wiki.ross-tech.com/wiki/index.php/02861
Lidt mere litteratur:
https://www.google.dk/search?q=ratstamm ... sAH_67XgAw
Der ligger denne TPI på det.
- 2022458_2.pdf
- (366.25 KiB) Downloadet 32 gange
- Tilmeldt: 13. jun 2008, 14:45
- Geografisk sted: Viborg
- Been thanked: 7 times
Hej HansHansH skrev:Mit umiddelbare gæt er ratstammelås. En kendt svaghed på B6.. måtte skifte den på min.
Er den nem nok at skifte og kode ? Og er har du evt et part nr
Edit. Fandt part nr. ved dog ikon det er nyest rev. da min etka ik duer
3C0 905 861 G
Mvh Jan
2018 Skoda Kodiaq 1.4 TSI DSG
Hej JanJan VJ skrev:Hej Hans
3C0 905 861 G
Til din fætters 2006'er er det samme partno som til min 2010: 3C0 905 861 J
koster i dag 101,27 EUR tysk listepris. Den er i gruppe 6 så den giver 10% hos AZF for os vag'ere...
Jeg valgte at købe den hjem fra AZF og så tage den med hen til aut. og lade dem dem montere den.
Selve montagen er egentlig ikke så slem ... man skal have ratsøjlen skilt ad nede i kardankrydset.
Men da den skal kodes til startspærre - og det kan jeg ikke - valgte jeg at købe stumperne hos AZF og så køre ud til min lokale Skoda, og lod dem montere den.
Forinden havde jeg for at lette deres arbejde, selv afmonteret ratsøjlebeklædning osv, så det var lige til at gå til for dem.
Jeg har vedhæftet org. faktura fra AZF på de stumper jeg bestilte, så du evt kan kopiere den bestilling (der skal nye bolte i kardankrydset når det har været skilt ad).
Derudover gav jeg kr 1.166,- for værkstedsarbejde.
Alt i alt godt 1.800.
- AZF_20160115_012464.pdf
- (283.68 KiB) Downloadet 46 gange
