Hej.
Var ved at lege med VCDS så jeg kunne kunne få DLA på min passat b8 2016. Men fik lavet ged i det.
Fik slået Headlight regulation til og fra. Så kom fejlen.
https://ibb.co/cLiChT
Kan godt clear fejlen, men kommer med det samme igen. Har prøvet at lave en reset basic headlight settings. Hjalp ikke.
Håber der er nogen der kan hjælpe.
På forhånd tak
Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 121
Mileage: 46163 km
Date: 2018.07.11
Time: 15:08:20
https://ibb.co/n1kEwo
Wednesday,11,July,2018,14:58:31:03671
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVWZZZ3CZGE205213 License Plate:
Mileage: 46163km-28684mi Repair Order:
Chassis Type 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 52 55 5F
6C A5 BB BC CF
VIN: WVWZZZ3CZGE205213 Mileage: 46163km-28684miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CZEA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BT HW: 04E 907 309 AB
Component: R4 1.4l TFS H23 9042
Revision: R6H23---
Coding: 0125003223641D083000
Shop #: WSC 05311 115 00301
ASAM Dataset: EV_ECM14TFS01104E906027BT 001010
ROD: EV_ECM14TFS01104E906027BT.rod
VCID: 77FC6112CEC313FC16-8022
CAN Converter 01:
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 040 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0605
Revision: 00005005 Serial number: CU501603046558
Coding: 0014
Shop #: WSC 05311 115 00073
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: 3B74BD22B26BF79C32-806E
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60736000000075
Coding: 0FEC6A8F342013710779060141C649F0562CC8E0608292F11822F078C2A2
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7AFA7826FDD10E9469-802E
2 Faults Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 202
Mileage: 35586 km
Date: 2017.12.05
Time: 17:45:07
32945 - Control Module for Electronic Parking Brake
C10E2 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 182
Mileage: 42981 km
Date: 2018.05.06
Time: 09:56:44
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0397920643
Coding: 000F0F0F03
ASAM Dataset: EV_KessyHellaMQBAB 004032
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID: 3978A72AB857C58C20-806C
Sensor Controlled Power Rear Lid:
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G1 907 044 P HW: 5G1 907 044 P
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020004200100011115504C0010190A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 3560AB1A944F21ECC4-8060
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
Relative humidity sensor in fresh air intake duct:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 865813031600J3
Coding: 00010E46C2C102FF4FC4401400140708188A000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 030405C28A1B4F5C3A-8056
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160224 042 0607
Serial number: 160226225435
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 30039579
Coding: 01006E
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 05 12 2015 10000598
Relative Air Humidity Interior Sender:
2 Faults Found:
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Mileage: 37861 km
Date: 2018.01.28
Time: 09:49:50
204546 - Remote key 2
B147A 18 [008] - Current Too Low
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391606807094
Coding: 0071155811
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 4486C6DECF95886443-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 32046FD25DFFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3466961E9F3538E4F3-8060
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSP4PBBU-
Coding: 88CCC000000000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EF27436E1F922B455-802A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G1857705G0067Q00017
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0063Q00656
Coding: 80000D
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 454 000 703 16
Component: SideSensor_Df 008 0887
Serial number: 3576U000000066359914
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 454 000 703 16
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000932059914
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 454 802 102 16
Component: SideSensor_Dr 301 0148
Serial number: 3516R3A71000A000000U
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 454 802 102 16
Component: SideSensor_Pr 301 0148
Serial number: 3526RD5A0040A000000%
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 454 800 402 16
Component: FrontSensor_D 304 0149
Serial number: 3556VF165F309000000I
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 EK HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF035035 Serial number: 20160212501343
Coding: 0C10
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7DF0733AECFF39AC4C-8028
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 411 1340
Coding: 07A40A186F9C00080A896F0B1000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009048
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 275C71525EE3437C46-8072
1 Fault Found:
16776980 - Databus
U1121 00 [009] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 187
Mileage: 43604 km
Date: 2018.05.20
Time: 09:21:03
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 11031610800903
Coding: 030300047F085700FB00025C1C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_VW37.rod
VCID: 79F8672AF8D7058C60-802C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160000444020016087
Coding: 2FFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9602389403
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000048075002
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71E85F0AA0A74DCCD8-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H04 0022
Serial number: Y0006PB712682
Coding: 0010000200000500818280808080000000008181000000F400
Shop #: WSC 41613 001 1048576
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
VCID: 3A7AB826BD51CE9429-806E
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 145
Mileage: 45968 km
Date: 2018.07.07
Time: 09:30:45
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 04C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
ROD: EV_RearRadarS1BoschVW48X.rod
VCID: 377CA1128E43D3FCD6-8062
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 101115BKA06136
Coding: 003F0B20D200028000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4384C5C2CA9B8F5C7A-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000661531
Coding: 01000011005000
Shop #: WSC 00015 115 00301
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
VCID: 3D70B33AAC7FF9AC0C-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 280116EAR00765
Coding: 003F0120DE00028200001000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428AC0C6D581865471-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 03DA000009010000
Shop #: WSC 05311 123 08193
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E06B1AD4CF61EC04-8020
1 Fault Found:
5275220 - Headlight
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 120
Mileage: 46155 km
Date: 2018.07.11
Time: 13:44:23
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 C HW: 3G0 035 043
Component: MU-H-N-EU H50 0343
Serial number: A683C0GB023272
Coding: 02840201FF00000051110001000808001F0100E401200000FF
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 1C365EBE17A590A4DB-8048
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9RKL0018H
Data medium:
Subsystem 2 - Part No SW: V03 959 800 QS HW: -----------
Component: ECE 2018 --- 0166
Serial number: --------------------
Compact Disc Database:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
1 Fault Found:
1637 - Interface for External Media
U11B8 00 [008] - No Communications
Freeze Frame:
Fault Priority: 4
Fault Frequency: 29
Reset counter: 158
Mileage: 46138 km
Date: 2018.07.10
Time: 22:35:00
Voltage terminal 30: 12.0 V
Interface for external media: status-Status: Open circuit
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 018402016600201F000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 C HW: 3Q0 980 654
Component: MQB_B_MFK H04 0023
Serial number: 08031611K11450
Coding: 0004080200000401002223568050A10094000E300040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_VW27.rod
1 Fault Found:
1122675 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 121
Mileage: 46138 km
Date: 2018.07.10
Time: 22:17:24
Control Module temperature: 37 °C
Outside air temperature: 22.0 °C
Vehicle speed: 0.00 km/h
System run time: 795.2 s
Voltage terminal 15: 11.6 V
mid: 01 E7
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 3
Software_Info_3: 2
Software_Info_2: 0
Software_Info_1: 0
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 240216EBN23603
Coding: 000E01200100028000001000
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 4580DBDAC4AFB16C54-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 240216EBN2370C
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
Address CF: Lane Chge Asst 2
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 06:33)--------------------------
Wednesday,11,July,2018,15:35:37:03671
www.Ross-Tech.com
Gateway Installation List: 5Q0 907 530 AJ
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Fejl lysængderegulering
- Has thanked: 10 times
- Been thanked: 178 times
Re: Fejl lysængderegulering
Du skal køre en forlygte indstilling og adaptation igennem. Vejledning på ross tech hjemmeside
- Geografisk sted: Horsens
- Been thanked: 124 times
Har du husket at godkende grundindstillingen
Når først du har valgt grundindstil forlygter i drop down menuen og trykket ok skal du vælge at godkende dem bagefter i menuen.
- Tilmeldt: 10. mar 2014, 13:08
Ja det var lige det jeg glemte
Ingen fejl mere. Tak for hjælpen
Skoda Octavia III 1.4 Tsi Elegance
