Fejl i CAN-Gateway
kreativ
Tilmeldt: 14. dec 2009, 16:01
Geografisk sted: Horsens
Been thanked: 124 times
Fejl i CAN-Gateway
Indlæg af kreativ » 13. apr 2012, 20:13
Jeg har denne i kanal 19 som hele tiden dukker op, har prøvet at slette den men den dukker stadig op, og kan ellers ikke se at der skulle være nogen problemer med parkeringsassistenten.
Er det mon noget kodningshalløj der skal til :?
Bilen VW Golf VI 1,6 BMT årgang 2012
Kode: Vælg alt
Thursday,12,April,2012,20:50:14:10074
VCDS Version: Beta 11.10.1
Data version: 20110801
Chassis Type: 5K0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 47 52 56 61 62 72
          76
VIN: WVWZZZ1KZCW260293
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYC)       Labels: None
   Part No SW: 03L 906 023 MM    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9050
   Revision: --H43---    Serial number: 00000000000000
   Coding: 08114036032401080000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM16TDI02103L906023MM 003006
   ROD: EV_ECM16TDI02103L906023MM_VW36.rod
   VCID: 7DF5FDC758D5
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 113B200D092800FA880D04ED901C0051350000
   VCID: 7BF1F3DF46C1
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000004003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW36.rod
   VCID: 800B0433AF27
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 40180A3A8825F3C0400800C0740081E44B510288636D8560648087200041
   VCID: 3A7F36DB097B
   Subsystem 1 - Part No: 5K1 955 119
   Component: Wischer 03021  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH
   Component: RLS 110212 05  54  0403
   Coding: 0230AD
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 1T0 919 475 P    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0116
   Revision: --------    Serial number: 13901132902284
   Coding: 10820A
   VCID: 489B5C134797
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RAFJMH5
   Coding: 00004431
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: 316D11F7D40D
   Driver's Airbag Crash Sensor:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME7666406AZZZ
   Passenger Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME4978756AZZZ7
   Driver's Rear Airbag Crash Sensor:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME743D682CZZZ3
   Passenger's Rear Airbag Crash Sensor:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME48566959ZZZ1
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   008 0080
   Revision: --------    Serial number:  90422LB2001FL
   Coding: 108A140000
   ASAM Dataset: EV_SMLSNGKUDS A05001
   VCID: 72EFDEFB118B
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Serial number: 70000000000000440570
   Coding: E20000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 882 A    HW: 5K0 920 882 A
   Component: KOMBI         H03 0407
   Coding: 170F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 2E570A8BC533
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 030212F2001698
   Coding: 350002
   VCID: 3B7133DF0641
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
            004 - No Signal/Communication
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0407
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   VCID: EADF469BB95B
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 F    HW: 1T0 035 680 F
   Component: RNS-MID       H60 3980
   Revision: AB001001    Serial number: VWZ6Z7L6241101
   Coding: 04070000010000AD0000
   Shop #: WSC 00001 001 00001
   ASAM Dataset: ------------------------- ------
   VCID: 316D11F7D40D
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2119
   Coding: 0135350
   VCID: 326F1EFBD10B
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 37792FEF3A69
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0006112
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1_VW36.rod
   VCID: 2A5F069BF9DB
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0135606
   VCID: 33611BFF2E11
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 316D11F7D40D
Address 61: Battery Regul. (J840)       Labels: None
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 1623
   Coding: 030F1859
   VCID: F1ED51F7948D
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 D    HW: 5K0 959 703 D
   Component: Tuer-SG         007 2101
   Coding: 0131216
   Shop #: WSC 01357 011 1012552
   VCID: 356525E72065
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 D    HW: 5K0 959 704 D
   Coding: 0131216
   VCID: 366722EB3D63
Address 76: Park Assist
Cannot be reached
End   ---------------------------------------------------------------------
ta5
Tilmeldt: 14. jun 2008, 09:33
Re: Fejl i CAN-Gateway
Indlæg af ta5 » 14. apr 2012, 06:52
Gå ind i can gateway og fjern fluebenet i 76 , du kan ikke både have parkeringshjælp (76) og parkassist2 (10) det er enten eller.
kreativ
Indlæg af kreativ » 14. apr 2012, 11:53
ta5 skrev:Hej.
Fedt! det hjalp sq :mrgreen: fejlen er væk igen.
Undrer mig bare over at den var aktiveret i 76 fra fabrikken, da jeg ikke selv har været inde og rode med det. Nå pyt fejlen er væk igen.
