Så er det nok nogen der bliver glade den nye S4 bliver trykladet.
Today Audi officially announced the new 3.0 TFSI engine, a new high-tech V6 combing Audi's latest state-of-the-art technologies – gasoline direct injection and supercharging, which indicates that the “T” in Audi's engine designation can no longer be solely associated with turbocharged versions. The new unit pumps out 290hp (213 kW) and a quite impressive 420Nm (310 lb-ft) of torque. Thrust of the compact supercharger, which sits inside the 90-degree V of the cylinder banks in place of the intake manifold, is available from idle speeds because it is belt driven, thus, enabling the unit to produce its maximum 420Nm of torque at just 2500rpm.
We can expect to see figures well under 10 liters per 100km (23.52 mpg) although final figures will vary depending on which model it is deployed in.
Audi is yet to confirm which models are likely to get the new 3.0 TFSI unit, but in line with the leaked engine offensive document we expect it to make its debut in the Audi A6 Facelift which will be released later this year and we should also see a tuned version make its way into the new S4 replacing its current 350hp V8 unit.
Mere Info for dem der kan tysk
http://www.audi.de/audi/de/de2/unterneh ... adung.html" onclick="window.open(this.href);return false;
Audi lancere ny motor 3.0 TFSI T=kompressor
- SteffenR
- Has thanked: 54 times
- Been thanked: 259 times
- SK Cor
- Tilmeldt: 13. jun 2008, 19:13
Re: Audi lancere ny motor 3.0 TFSI T=kompressor
lyder spændende - tror dog næppe den når BMW 3,0L turbomotor til sokkeholderne.
- Roeden
- Tilmeldt: 13. jun 2008, 12:30
- Geografisk sted: Holte
- Has thanked: 70 times
- Been thanked: 70 times
Enig, den funker bare, og har maks moment allerede ved 1300 rpm, men det blir da spændende at se hvad det ender med
Roeden
Roeden
Sommer: 07' MB CLK63 Cab
Hele året: 24' BMW i4 M50
Fruens:
21' MB GLE
tidligere:
22'Cupra Formentor VZ 310
21' MB S205 300d 9G-Tronic AMG night
Fruens:
21' MB GLE
tidligere:
Skuffende at en trykladet motor ikke engang laver 100hk pr liter, som mange sugemotorer laver std......
- Been thanked: 35 times
nu er det jo ikke hverdagskost at se sugemotorer lave 100hk/l men ja, der er da nogle stykker, men det er ikke familiebiler alle sammen.
svan
svan
