Audi S3 8P 2.0 TFSI – APR Stage 3 med GTX2867
Re: Audi S3 8P 2.0 TFSI – venter på stumper
Indlæg af kimhemm » 3. aug 2014, 22:30
Og med lækkert manifold
Attached to the turbocharger is APR’s investment-cast, super alloy, nickel-chromium-based Inconel 625 Manifold featuring APR’s Sequential Exhaust Pulse runner lengths. Unlike hand welded tubular manifolds, Inconel is a very high temperature resistant material designed to withstand extreme exhaust gas temperature changes without expanding, contracting, melting or cracking under stress. This material is typically found only at the highest levels of professional motorsport racing where reliability is essential to success.
Investment-cast Inconel features heat retention characteristics which aid in turbo response by keeping exhaust velocity high. Ensuring each exhaust pulse arrives at the collection point without collision is critical to producing lightning fast response and immediate torque delivery. Using 3D modeling and computational fluid dynamics software, APR’s Engineers designed varying short runner lengths calibrated to deliver sequential exhaust pulses without collision. A reduction in backpressure from the high flow design directly enhances power delivery.
Each manifold is investment-cast in the United States of America and machined in house on APR’s CNC machines to ensure high casting tolerances, repeatable results and strict quality control. The thick casting material reduces unwanted exhaust noise leaving behind a powerful and exotic growl.
All of these characteristics result in a manifold designed without compromise backed by a confidence inspiring lifetime warranty.
Indlæg af kimhemm » 3. aug 2014, 22:32
Med i kittet er der også nye siliconeslanger
Wire reinforced, multi-ply silicone hoses provide an unrestricted path for airflow to enter and exit the turbocharger at over 1,000 kilograms per hour. The ultra rigid design ensures boost and vacuum piping will not swell or collapse causing leaks and restrictions in the induction and charge piping system supporting boost response and turbo recovery. Each hose is engineered to fit properly into the vehicle's engine bay with all necessary emissions and reference ports securely affixed.
APR’s Easy-Flow Silicone Hose design features stepped mounting surfaces for smooth transitions from one pipe to another. Traditional designs simply sit on top of each other, often resulting in a disruptive airflow path. By using the stepped design, hoses fit properly without airflow restrictions, resulting in the most ideal path for moving air through the turbocharger and into the engine.
Indlæg af kimhemm » 3. aug 2014, 22:33
Nyt trykrør fra turbo er også med
To provide unrestricted and smooth airflow from the turbocharger to the intercooler, the APR Stage III GTX Turbocharger System includes a cast enlarged turbo outlet pipe to properly deliver the additional airflow from the larger turbocharger.
Indlæg af kimhemm » 3. aug 2014, 22:34
Og med mere power skal der også et 3" MAF hus på
The 2.0T’s engine management relies on load calculations to accurately control the engine. Calculations are made by measuring airflow across the Mass Airflow Sensor and this is a critical component of the APR Stage III GTX Turbocharger System.
The Golf R's and S3's small and restrictive factory unit is removed and replaced with the much larger housing. The TT-S factory MAF housing differs and therefor a different part is included. To ensure accuracy, APR’s MAF housing is cast in the United States of America and CNC machined in house at APR to ensure repeatable results. The long, precision-machined housing features a honeycomb airflow straightener to further aid in accurately reading airflow levels. Simply enlarging the MAF housing is not permissible without accurate adjustments to the factory engine management system, which is included with APR Stage III GTX Turbocharger System.
Indlæg af kimhemm » 3. aug 2014, 22:36
Nye olieslanger skal der også til
APR’s oil and coolant lines are specific to the 2.0T Stage III GTX System and provide years of leak free operation. The oil lines feature flexible braided stainless steel with CNC mandrel bent hard-lines for specific and clean hose routing as if intended by the OEM.
Indlæg af kimhemm » 3. aug 2014, 22:38
APR's egen returventil til dysebroen
The factory 2.0T gasoline direct injection injectors require higher than factory fuel rail pressure to achieve targeted air fuel ratios under high load, wide open throttle operation. APR’s Low Pressure Fuel Pump delivers the desired volume of fuel to the APR High Pressure Fuel Pump, which provides increased fueling headroom over the factory unit. However, the factory High Pressure Fuel Rail Valve limits maximum rail pressure below the desired level. The included APR High Pressure Fuel Rail Valve is calibrated to increase the maximum rail pressure to levels necessary for proper operation.
In doing so, APR’s able to support far higher horsepower levels than achievable on the existing APR Stage III GTX Turbocharger Systems without the need to alter the OEM correct-spray-pattern injectors. This results in smoother part throttle operation, factory-like cold starts and fewer unburned hydrocarbons emitted from the tailpipe under all conditions compared to other fueling options.
Indlæg af kimhemm » 3. aug 2014, 22:39
Og nyt forrør da det gamle ikke passer på længere
Indlæg af kimhemm » 3. aug 2014, 22:40
Og der er alle små beslag og skruer osv med der skal bruges til monteringen af kittet
Every APR Stage III GTX Turbocharger System includes all necessary components for a complete install.
Indlæg af kimhemm » 3. aug 2014, 22:41
Kvalitet selv over de små beslag
No matter how small the part, each piece of the APR Stage III GTX Turbocharger System oozes with quality evident in pieces like the Stage III's laser cut ancillary brackets and carriers.
Indlæg af kimhemm » 3. aug 2014, 22:42
Og tændrør som APR mener passer til kittet
Proper temperature range spark plugs are included with each APR Stage III GTX Turbocharger System.
ABT
Tilmeldt: 16. jun 2008, 08:52
Geografisk sted: Jydeland
Has thanked: 26 times
Been thanked: 16 times
Indlæg af ABT » 3. aug 2014, 22:44
Du bliver ved og ved.. 8-)
Fine sager!
Bliver spændende og se det på bilen og det endelig resultat.. :geek:
Indlæg af kimhemm » 3. aug 2014, 22:45
Udover APR stage 3 kittet som faktisk kan monteres og køres ind på en standard motor (Cupra, S3, Golf R) og levere en fin effekt har jeg også fået lavet lidt ekstra.
APR/Mahle stempler i 83mm boring, passede super da de gamle der sad i var på 82,44 så nu kunne blokken bores op og blive fin og ren og klar til mere (forhåbentlig) power og lavet så vi ved det holder
Quick Facts
Forged pistons
Proprietary APR / MAHLE design
Proprietary MAHLE 142S alloy
Low noise materials
Low thermal expansion for tighter tolerances
OEM piston compression bowl profile
83mm oversized design
9.9:1 compression ratio
MAHLE 22mm German tool steel wrist pins included
MAHLE low-drag rings included
Top - Barrel-Faced Steel (File to Fit)
Second - Tapered Face Ductil Iron (File to Fit)
Oil Rings - 3 Piece Standard Tension
318 grams per piston
Hard anodized top ring grooves to prevent micro-welding
MAHLE proprietary Grafal anti-friction coated skirts
OEM oil squirter notches
First landing accumulator grooves for top ring seal promotion
Ultra flat ring grooves for ring seal promotion
Indlæg af kimhemm » 3. aug 2014, 22:48
Og et sæt APR/Mahle plejlstænger (som var længe ventet...)
Quick Facts
H beamTapered H-Beam Design
Strong weight saving design
Wrist Pin Oil Passage
Additional wear resistance
Diamond Honed
Surface finishes with consistent RA
Double Re-Melt Forging
Improves metal quality
Cryogenically Treated
Improves strength
Tapered Wrist Pin
Additional weight savings
Alloy Construction
High strength and light weight alloy
Magnaflux Tested
Casting quality control
Balanced to +/- 1 Gram
Increased reliability & performance
Vacuum Heat Treated
Improves strength
100% USA Certified Alloys
Improves quality and control
Drop-In Compatibility
Works with no other modifications
AMPCO 45 Bushing
Exceptional wear resistance
Rockwell Tested
Hardness testing
Tolerances to Factory Specs
OEM quality fit
Surfaced Peened
Improves fatigue strength
100% Made In the USA
Materials, forging, treating, etc
ARP2000 Hardware
High quality and strength bolts
Indlæg af kimhemm » 3. aug 2014, 22:51
ABT skrev:Du bliver ved og ved.. 8-)
Fine sager!
Ja tænkte det måske var lettere med lidt mindre indlæg om delene fremfor et meget langt som så bliver et helvede når/hvis nogen quoter det :D
Men ja, jeg glæder mig også snart til at se den på vejen igen. Tror nok at der er lidt luft i kalenderen her efter sommerferien fra kundebiler så håber min får en tur nu :D
Kevinff
Tilmeldt: 25. jan 2012, 10:33
Has thanked: 967 times
Been thanked: 508 times
Re: Audi S3 8P 2.0 TFSI – venter på tid - update 03-08-14
Indlæg af Kevinff » 4. aug 2014, 08:54
Hvad skulle den lande på af effekt Kim? Lyder sku spændende :)
Indlæg af kimhemm » 4. aug 2014, 09:35
Kevinff skrev:Hvad skulle den lande på af effekt Kim? Lyder sku spændende :)
Skulle være omkring 460-470 HK på standard motor og så har jeg fået lidt større stempler og bearbejdet topstykke på og så må vi se hvad vi ellers finder på af små sjove ting
Det er egentlig ikke så meget topeffekten jeg går efter, men at få lavet en bil der kan bruge de kræfter den har og så helst få en god bred effektkurve
Kevinff
Indlæg af Kevinff » 4. aug 2014, 09:49
Hold da kæft :o men ja det vigtigste er klart at bilen kan bruge sine kræfter og den faktisk er til at køre :)
Indlæg af kimhemm » 4. aug 2014, 10:05
Kevinff skrev:Hold da kæft :o men ja det vigtigste er klart at bilen kan bruge sine kræfter og den faktisk er til at køre :)
Ja ikke
Vi har lavet en Golf R for en kunde der med standard motor og standard DSG software kørte 1/4 mile på 11,6 til DHB. Det var med en 60 fods tid på 2,05 og den kan/bør med DSG optimeret ligge på 1,6-1,7 så der kan man godt trække lidt fra. En kunde i Australien har lige kørt under 11 sec med hans Golf R. Så selvom det er en "lille" turbo kan den godt levere
Kronborg
Tilmeldt: 15. feb 2009, 19:23
Geografisk sted: Brønderslev
Been thanked: 100 times
Indlæg af Kronborg » 5. aug 2014, 20:04
Hold kæft det bliver godt :D
mtech
Tilmeldt: 16. jun 2008, 15:18
Geografisk sted: sydsjælland.
Indlæg af mtech » 5. aug 2014, 20:53
Ja ikke
Det sku en fin tid.. 11 sek er en hurtig gadebil :) pph motorings rs3 er da ikke meget hurtigere..eller er det ca det samme?
Golf R36 Turbo
60ft 1.41s
1/8mile 5.81s@204km/t
1/4mile 8.86s@262km/t
Med andre ord:
0-204km/t 5.81 sek
0-262km/8.86sek
Indlæg af kimhemm » 5. aug 2014, 22:34
Kronborg skrev:Hold kæft det bliver godt :D
Ja der skal lige de sidste par småting hjem :D
Indlæg af kimhemm » 5. aug 2014, 22:35
mtech skrev:
Ja ikke
Har ikke helt fulgt med i tiderne på RS3 men ja en 11 sek gadebil er pænt hurtig. Sådan en Golf R får overført kræfterne effektivt
Indlæg af kimhemm » 16. okt 2014, 22:27
Update 17 september
Update fra idag 16 oktober
Mangler lige at få et par småting hjem som er blevet taget fra mit kit til kundebiler men nærmer sig stille og roligt og håber at nå et par ture i den før salten kommer :)
Sputte
Tilmeldt: 15. jun 2008, 00:02
Geografisk region: Tyskland
Geografisk sted: Warszawa
Indlæg af Sputte » 17. okt 2014, 06:09
Vanvittigt, jeg var egentlig sikker på du havde givet op.
Indlæg af kimhemm » 17. okt 2014, 06:25
DkSputte skrev:Vanvittigt, jeg var egentlig sikker på du havde givet op.
Nej da, men det har bare været elendig timing med tid på værkstedet til at lave egne projekter og så har jeg valgt ikke at stresse over det
melander1980
Tilmeldt: 2. jun 2009, 19:17
Geografisk sted: Kgs. Lyngby
Indlæg af melander1980 » 17. okt 2014, 07:21
Den bliver super fed Kim
Martin
Tilmeldt: 13. jun 2008, 11:16
Has thanked: 120 times
Been thanked: 121 times
Indlæg af Flamiq » 17. okt 2014, 07:38
kimhemm skrev:Update 17 september
Jeg skal nok gøre mit til, at der ikke kommer nævneværdigt med salt på de københavnsk veje - Ihvertfald i indeværende kalenderår 8-)
Så sæt igang ;)
Sputte
Indlæg af Sputte » 23. okt 2014, 09:18
Vender I motoren igen næste måned? ;-)
Indlæg af kimhemm » 23. okt 2014, 09:21
DkSputte skrev:Vender I motoren igen næste måned? ;-)
Haha, godt set :D
Indlæg af kimhemm » 23. okt 2014, 19:43
Lidt fremskridt idag, begynder at ligne noget. De store ting er vist efterhånden ved at være på plads og mangler "bare" lidt småting der skal hjem
