Hey,
Ham her gutten i den her 1.8T Golf 4 har Acc. graf i hans FIS display.
Nogle der har ide om hvordan han har fået det?
LINK: http://youtube.com/watch?v=cyGJUuYPu2w&feature=related" onclick="window.open(this.href);return false;
Acc. graf i FIS på Golf4?
- Tilmeldt: 15. jun 2008, 07:49
Re: Acc. graf i FIS på Golf4?
Det er ikke acceleration men ladetryk grafen viser.
Det ser ud til at være E-MFA systemet som kan købes hos Kufatec:
http://www.kufatec.de/shop/product_info ... -IV-4.html" onclick="window.open(this.href);return false;
Audi A3 Sportback 2.0 TFSI Quattro, 2007
- kimhemm
Der er flere på seatclub der har købt hjem fra dem her : http://store.l-c-t.com/store/category/AUDI.html" onclick="window.open(this.href);return false;Supermule skrev:Kan det laves til en RS6'er(4B)
Prøv evt. at kontakte dem ang. din Audi RS6 om de har noget til den. Ved at Altea ikke står på listen, men der er en der har fået noget hjem der virker fint.
Her er mulighederne, beskrevet på engelsk:
NEW: now with DBBS technology - dynamically adjusts to the dashboard processor speed for best results
- NEW: now with REALSPEED technology - finally allows accurate acceleration measurements
- NEW: REALSPEED can be shown in MPH or KMH
- NEW: REALSPEED has been verified to be nearly 100% accurate when compared with dyno runs
- NEW: improved window remote function - works with even more configurations
- NEW: improved security to avoid accidental window operation through the remote control
- NEW: improved boost signal detection when the signal reported can not be identified correct
- NEW: improved atmospheric pressure detection even when the data reported is incomplete
- NEW: added support for some factory radio SW versions to avoid accidental track/station changing
- NEW: improved display error handling on slower network configurations to avoid display reset
- NEW: improved radio interface to support more non standard, non OEM radio installations
- NEW: improved harness - now more flexible and at the same time more durable
- NEW: does not interfere with factory brake light assist if present
- NEW: automatically disables the flashing indicators on reverse if either turn signal is engaged
- NEW: sampling frequency has been increased for certain sensors to further enhance accuracy
- NEW: allows manual mirror adjustment when mirror is in Parking Assist position
- NEW: over 40 changes to existing functions to improve performance and compatibility
- display the calculated on pavement Horsepower and the calculated torque (in NM or lb-ft)
- display the RPM on the MFD
- highest torque value temporary hold - allows for much better reading
- display 0-60 mph time on the MFD (dashboard) in realtime
- display 0-90 mph time on the MFD (dashboard) in realtime
- display quarter mile time on the MFD (dashboard) in realtime
- display half mile time on the MFD (dashboard) in realtime
- display 0-100 kmh time on the MFD (dashboard) in realtime
- display 0-140 kmh time on the MFD (dashboard) in realtime
- display 400 metre time on the MFD (dashboard) in realtime
- display 800 metre time on the MFD (dashboard) in realtime
- speed trap system now easier to use with all models, allows for "dirty" runs
- display the turbo boost pressure on 2.0tfsi or 1.9/2.0tdi engines on the MFD (dashboard) while driving
- change between absolute or relative boost pressure display in KPA, PSI or BAR
- highest boost value temporary hold - allows for much better reading
- show the maximum relative boost pressure recorded in BAR on each valid test run
- display the actual o2-sensor (lambda) readings on the MFD (dashboard) in realtime
- allowing to select between 2-6 comfort blinks (factory is only OFF or 3) on either indicator
- automatically open/close the windows with the factory key remote
- open only the front windows or all windows with your key remote - just on the push of a button
- adding a special indicator or horn sequence while you are in reverse gear
- adding emergency Brake Light Assist
- adding Mirror Park Assist (flips down the passenger side mirror so you can see the curb)
- temporary mirror park assist disable (no need to enter the menu to disable it)
- features work with all automatic or manual shift and with or without steering wheel buttons
- works with other engines as well - all functions except for the boost display page are available*
- functions can be configured through our exclusive on dash menu via the MFD
- the module can be switched off to be completely invisible to any workshop
- easy installation - takes less than 5 minutes, no additional tools required
- full plug and play installation: no wires to cut or splice!
- kimhemm
Og mener at det er "duckstar" herinde fra der har monteret det i hans Skoda og tipset om det inde på seatclub...
- Has thanked: 92 times
- Been thanked: 189 times
kimhemm skrev:Og mener at det er "duckstar" herinde fra der har monteret det i hans Skoda og tipset om det inde på seatclub...
Jep, den laver dog ikke en graf men ladetryk i absolut tryk og det efterlyste acc. 0-100 og 402 meter virker fint til husbehov
- Tilmeldt: 16. jun 2008, 00:06
Ser rigtig lækkert ud.
Nogle der ved om det er noget skidt at installere på sådan en som min? (1.8T fra 00)
