VCDS + IPAD
- norn
- Been thanked: 212 times
VCDS + IPAD
er der en mulighed for at få det til at fungere sammen....
for så tror jeg sku nok der skal indkøbes en æblemaskine
Lindegaard
- Tilmeldt: 13. jun 2008, 14:23
- Geografisk sted: Ørbæk
- Has thanked: 9 times
Sv: Re: VCDS + IPAD
Hvorfor skal det foregå på pb? Kunne det ikke være der var andre, som osse gerne ville høre om det...?:)RIX skrev:send en pb til anders D
Jeg vil gerne....
Sendt fra min MB525 med Tapatalk
Touran 2.0 TDI 170hk DSG Highline 7pers Fuld læder
Passat TDI Variant, 3b afn, Highline. SOLGT
Golf III TDI 1z SOLGT
Touran 1,9 TDI 7pers 03 SOLGT
- norn
Re: VCDS + IPAD
ja hvorfor på pb....???? det er måske topsecret
- Dasker
- Geografisk sted: Vinderup
Re: VCDS + IPAD
Det ville jeg sku også godt vide.
Tror bare ikke at man kan få det til at funke, da vcds ikke er skrevet til ipad.
Men man kan sagten lave en usb port på ipad, med sådan en kamera tilslutnings tingeste.
http://www.dealextreme.com/p/hdmi-usb-h ... hite-73319
Feks denne
edit********************
Fandt lige dette, de snakker lidt om BT, så giver det også mening.
1.9 Will there be a version for iPhone/iPad, Android, Blackberry, or Windows Phone 7?
We are not planning to make a native "Application" for any of these platforms. Instead, we have begun working on an approach to support modern mobile devices in a completely platform independent way. This project is still in its infancy and there is no estimate of a completion date, so please don't waste our time asking when it will be ready. When it is ready, we won't keep it a secret!
In the meanwhile, the most portable way to run VCDS is to use a Netbook PC. These are small enough to fit in your glove box and cost less than a typical smart phone. Current ones usually come with Windows 7 Starter Edition, and VCDS works fine with this. Older ones normally came with XP-Home and VCDS works fine on that as well.
Feks denne
mvh:
Kenneth Askov Hansen
Kommende projekter:
VCDS Altid nyeste version.
Kommende projekter:
- kws
- Geografisk sted: Randers
- Has thanked: 135 times
- Been thanked: 75 times
Re: VCDS + IPAD
Det er vel bare at smide windows på ipad'en og så fixe en usb port..
jeg kan umiddelbart ikke se et problem i det
http://www.version2.dk/artikel/vmwares- ... ipad-18391
- VW Bobbel 1200 1973
- Tesla Model Y 2023
- theone
- Geografisk sted: Fredericia
Re: VCDS + IPAD
Hmm.. Den kan jeg ikke finde i AppStore?
- kws
Re: VCDS + IPAD
http://itunes.apple.com/us/app/vmware-v ... 93697?mt=8theone skrev:Hmm.. Den kan jeg ikke finde i AppStore?
- Geografisk sted: GALTEN
- Has thanked: 365 times
- Been thanked: 104 times
Re: VCDS + IPAD
du kunne jo være anders ikke så tråden
derfor
ikke fordi det skulle være hemligt
derfor
- Dasker
Re: VCDS + IPAD
Hvad med sådan en her.
Jeg ville helst bruge min ipad, men dette er da en mulighed.
http://www.dealextreme.com/p/10-1-capac ... -ssd-65761
mvh:
Kommende projekter:
Kommende projekter:
