Golf R - input til diverse modifikationer
Alt vedr. udstødningsystemer
lazzen
Tilmeldt: 11. jan 2026, 12:35
Indlæg af lazzen » 11. jan 2026, 16:00
HALLO GODDDAG :-)
JEG HAR AF 2 OMGANGE KØRT OG HAFT VW GOLF R 2.0 . FORST EN GOLF R PÅ TYSKE PLADER JEG BOEDE I FLENSBORG DENGANG HAVDE DEN I TO ÅR. DEN FØRSTE VAR EN 2.0 R DSG 4MOTION MK 7.0. NUMMER TO HAR JEG LIGE NU, JEG HAR HAFT DEN I EN GOD RUM TID OG NU VAR DET SÅ TIDEN TIL DER GERNE MÅTTE SKE LIDT IKKE FORDI DE 310 HK VAR EN MANGEL MEN LIDT MERE GØR JO VEL IKKE NOGET. STAGE 2 PÅ 400 HK VAR SLUTRESULTATET. SÅ VILLE JEG HAVE MONTERET EN DOWNPIPE CATLESS.
MEN EFTER RUNDSPØRGE GIK JEG FRA DET IGEN. FORDI JEG FIK OPLYST AT NÅR OG HVIS MAN PILLER DEN ORIGINALE DOWN AF. MISTER MAN JO PARTKKELFILTERET OG IKKE MINDST KATALYSAOREN. JEG FIK OPLYST AT DER SÅ MED STOR SANDSYNLIGHED VILLE OPSTÅ FEJL MELDING SÅ GIK FRA DET !!! ( ER DER NOGEN HERINDE DER KAN KLARLÆGGE HVORDAN MAN UDGÅR EVT FEJL PÅ MOTORSTYRINGEN VED UDSKIFT AF DOWNPIPE ( DET LYDER JO LOGISK MEN EFTER HVAD JEG BL..A HAR LÆST MIG TIL OG SET PÅ YOUTUBE ER DER INGEN DER NÆVNEREN HUJENDE FIS OMKRING DETTE HVERKEN OM CAT OG ELLER PARTIKKELFILTER NÅR DE EVT. FJERNES HMM. NOGEN HAR ET KVALIFICERET BUD ??
JEG HAR ANSKAFFET ET NYT LUFTINTAG," RACING " DER ER IHVERTFALD STØRR END DET ORIGINALE BÅDE FILTER OG SLANGER.JEG PILLER DET ORIGINALE UD OG SKIFTER TIL CA. 2.5", JEG VIL SKIFTER INTERCOOL DELENS SLANGER OG OPGRADERE DEM. EFTER PRINCIPPET " SUCK - BLOW - BANG " " STØRE ER HER GODT !! "
NOGEN DER HAR N KOMMENTAR ER ÅBEN FOR BÅDE POSITIV OG NEGATIV FEEDBACK :-)
SENERE VIL JEG OPGRADERE FRONTGRILL TIL IMITERET KULFIBER HONEYCOMB MESH ELLER ABS PLAST. DET DET VIGTIGT FOR MIG ER " KARRETEN " SYNER ENS I LOOKET !!
( HAR BESVÆR MED AT FINDE ENS LOOK UDEN DET KOSTER, SPIDSEN AF EN JETJAGER, DET ER JEG IKKE LIGE SÅ HOOKED PÅ LIGE NU!!
JEG HÅBER PÅ I VIL DROPPE JERES MENINGER PÅ FORHÅND TAK !!
MVH
JOHNHY
Monze1980
Tilmeldt: 17. jan 2013, 21:31
Has thanked: 506 times
Been thanked: 764 times
Re: NY BRUGER OG NU SKAL DER BARE SKE NOGET MED GOLFEN !!!
Indlæg af Monze1980 » 11. jan 2026, 16:12
Velkommen til......fremover skal du nok lige sørge for at din caps lock ikke sidder trykket ned 🫣
Går ud fra du mener folk skal skrive deres meninger....og ikke at de skal droppe dem (altså opgive dem).
Sendt fra min CPH2747 med Tapatalk
Indlæg af Watcher » 11. jan 2026, 16:17
TaG fAt I sTrEeTpOiNt SoM oGsÅ hAr LoVlIgTuNiNg.Dk Så KaN dU fÅ eN gOdKeNdT lØsNiNg TiL dIn BiL Og SkReVeT iNd I pApIrEnE aT dEn Er TuNeT sÅ dU iKkE rIsIkErE aT bLiVe StOpPeT oG fÅ kOnFiSkErEt DiN bIl.
Du KaN sAgTeNs Få Et FoRrØr MeD sPoRtSkAt På InGeN pRoBlEmEr I dEt, OgSå Et SoM eR gOdKeNdT dEt KoStEr IgEn BaRe FlErE pEnGe EnD eT iKkE gOdKeNdT cFøLi
MaN bEhØvEr AlTsÅ iKkE rÅbE hElE tIdEn.. MaN kAn GoDt BaRe SkRiVe NoRmAlT
These users thanked the author Watcher for the post (total 7):
jenckaMikkel GNaffeRandom_HeroRealtorSchmidtgauner
asej
Tilmeldt: 23. jun 2008, 07:05
Has thanked: 39 times
Been thanked: 70 times
Indlæg af asej » 11. jan 2026, 17:02
Watcher skrev:
11. jan 2026, 16:17
MaN bEhØvEr AlTsÅ iKkE rÅbE hElE tIdEn.. MaN kAn GoDt BaRe SkRiVe NoRmAlT Billede
Tør ikke tænke på hvor lang tid det har taget at skrive :lol:
Re: Golf R - input til diverse modifikationer
Indlæg af Watcher » 11. jan 2026, 17:32
asej skrev: Tør ikke tænke på hvor lang tid det har taget at skrive :lol:
Jeg har ikke noget imod at gå det extra skridt for at gøre folk glade i min hverdagBilledeBillede
These users thanked the author Watcher for the post (total 16):
tvartoujohn makaupMichaelSmedMikkel GJSKristensenNaffeEsbenJmertodinloDecolour and 6 more users
Tilbage til "Udstødning"
